Mates,
I cannot get my new BEO6 to 'find' my BS5 on the network.. .
The time capsule does not have an 'easy' button. . but the connection to the network seems to be fine. .
I have good signal strength showing up in the right hand corner. . .
any ideas? has anyone used the BEO6 with the apple time capsule?
thanks
MJM
I'm ready for something new that I actually want to buy!
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
As Said in the General forum, check server ip in the Beo6 wireless menu, should be BS5 ip, and replace BS5 in the CT with the new version in CT 5.12.
This helhed to get my Beo6 Working 2way in my setup with BS5/BM5 and airport Extreme - no TC.
Stefan
My Beo6 works also with the AirPort Extreme. Just use the correct IP address.
The Beo6 only works with 2,4Ghz. The Beo6 could not find my 5Ghz Wireless.
