Latest post 11-16-2011 6:51 AM by tournedos. 6 replies.
Page 1 of 1 (7 items)
  • 05-09-2011 7:14 AM
    • pbda
    • Not Ranked
    • Joined on 05-07-2011
    • London
    • Posts 9
    • Gold Member
    Beomaster 4000 vs. 4400
    With a Beogram 4000 now under the roof (thank you Peter for your helpful advice on cartridges), it seems a shame not to match it to an era-appropriate receiver.
    My understanding is that the Beomaster 4000 is the "correct" match for this deck, but the 4400 seems to have better specs, as well as a silver faceplate (which I prefer from an aesthetic point of view).
    I'd be most interested in thoughts on the pros and cons of these receivers as a match for the Beomaster.  Many thanks in advance.
  • 05-09-2011 7:35 AM In reply to
    Re: Beomaster 4000 vs. 4400
    I'd go with a 4400, as I think that the alu fascia better matches  the Beogram 4000. It delivers a wealthy 75 watts in 4 ohms, has accurate sound shaping options, a nice FM radio and options for two tape decks. The 4400 is basically a developed version of the 4000, the difference isn't that big at all Smile
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 05-09-2011 9:46 AM In reply to
    • BenSA
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    I've owned both and decided in the end to keep the 4400 and sell the 4000.
    4400 is much better!
    Durban South Africa
  • 05-09-2011 10:27 AM In reply to
    From what I (as an electronic idiot) understand, the 4400 is actually quite distinct from the 4000 and its forebears. There is an interesting paper on its development on site which, although written by B&O , explains the various strategies employed in the design. One of the problems the 4400 has is that it does resemble the 3000 and 4000 and is seen as a development rather than a completely different model. The later Beomaster 6000 actually shares a lot of the same design and even the 8000 owes a large part of its architecture to that of the 4400 though expanded in areas such as the power supply. I think the fit and finish of this model was not achieved in the later models and was beaten only by the Beolab 5000 system of 10 years before.
    I actually like the black finish and therefore have a Beomaster 4401!
  • 05-09-2011 3:17 PM In reply to
    I think the Beomaster 4400 is probably the best combination of sound and build quality of any of the B&O receivers that I have owned or heard and is almost contemporary with the BG4000.  I love my 4400 and listen to it above all others now, even my BM 8000-based system.
    Tim Jarman calls it the 'audiophile's choice' from the Beomasters and with a really good pair of contemporary speakers - for small rooms, S45.2s, or even better, at least if you have the space,  M75s or M100s, you will have a magnificent, accurate and musical system from the seventies.
    It will also drive odd loudspeaker loads - for example, 15ohm speakers or even Quad Electrostatics ESL 63s without any trouble at all.   And a CDX works really well with it.
    Cleve
  • 11-16-2011 6:46 AM In reply to
    • pbda
    • Not Ranked
    • London
    • Posts 9
    • Gold Member
    Many thanks to previous posters for their thoughts.  I've gone and aquired the Beomaster 4400 and have hooked up my Beogram 4000 to it.  Now to get the tuner working properly I need to find an antenna/aerial to suit.  Am I correct in assuming that I need to find one with a male PAL connector?
  • 11-16-2011 6:51 AM In reply to
    pbda:
    Yes - but just a piece of wire will get you started.
    The connector you need is known by a lot of names, you can read more here.
    Congratulations on the 4400! Smile
    -mika
