Latest post 10-08-2011 8:54 AM by Vienna. 5 replies.
Page 1 of 1 (6 items)
  • 10-07-2011 6:28 PM
    Beolink Active on iMac?
    I am thinking about connecting my Bl6000 to a beolink active and this one to my iMac. The BL-active has the PC input.
    The question is: would the Bl6000 power on when the iMac sends sound signal? Or would I need to use a remote to first switch the BL active to PC to hear the sound from Mac?
    Thanks for the support.
    Heribert
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 10-07-2011 7:03 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Beolink Active on iMac?
    1) the BeoLink Aktive has to be connected to a ML-System,
    2) You need a remote to swich to the local "PC" input of your BeoLink Aktive
    3) You need a special adapter cable - it's not standard DIN pinout
    http://forum.beoworld.org/forums/p/15997/281702.aspx#281702
    1. SL-config
    2. LEFT IN
    3. Left out
    4. RIGHT IN
    5. Right out
    6. Data -
    7. GROUND / SHIELD
    8. Data +
    Filed under: , ,
  • 10-08-2011 2:33 AM In reply to
    Thanks Vienna.
    One more thing: would I be able to switch on the PC Mode with the IR puck?
  • 10-08-2011 5:02 AM In reply to
    • Vienna
    • Posts 712
    Heribert:
    ...would I be able to switch on the PC Mode with the IR puck?
    Sorry, not sure to understand your question completely. Confused
    A BeoLink Active can only be controlled via a remote control *)
    (eg Beo 4/5/6 - sending IR commands to the "IR-Eye").
    To switch to the PC socket of a BeoLink Active using a BEO4
    you'll have to select "PC" from your [List] and then [GO/PLAY].
    Using a BeoLink 1000 you'll have to press [SHIFT]+[STORE].
    You can NOT distribute the signal of the local source (your computer)
    connected to the PC input to other rooms of your ML System.
    *) unless you have a ML-Gateway in your setup ...Smile
  • 10-08-2011 5:09 AM In reply to
    The question was more with regards to the IR puck that is connected to the BL Active. As far as I know this has buttons for on/off and/ or volume control.
    I want to avoid the requirement to use a Beo4 odor hearing the Mac sound out of the BL6000. On the other hand I would like to listen Radio from my audio master in my office with the iMac.
    I currently use a Beoport but want to sworn to BM1 or BM5 in future.
  • 10-08-2011 8:54 AM In reply to
    • Vienna
    • Posts 712
    Heribert:
    Yes, manual control via the "IR puck / IR-eye" only for "on/off" and/or "volume control".
    Full control, eg. selecting a source only via IR-remote or a ML-GW.
    Heribert:
    Smile A Windows-PC + BeoPort Box + BeoPort Software would exactly do what you want.
    ... maybe the geeks from Beo-Mac can help you ...
    Heribert:
    Even when BM1 or BM5 is connected to the main TV - my choice for a home office still would
    be a WIN-PC + BeoPort + BeoLabs + BeoPort SW on the desktop.
    But a friend of mine uses in a similar BM5 config a MAC + BeoLink Active + Beo4 + BeoLabs
    in the home office ... telling me, he prefers the devil to the deep blue see - or was it the other way 'round?
