Latest post 10-05-2011 12:08 PM by valve1. 3 replies.
Page 1 of 1 (4 items)
  • 10-04-2011 11:50 AM
    • Beeme
    • Not Ranked
    • Joined on 10-04-2011
    • Posts 2
    BeoCom 6000 no dial tone - no signal
    Hi, I need advice on my BeoCom 6000 Mk1 which has stopped working. I have 3 handsets all still registered to the base station and although all still work for internal calls between handsets, I can't get a dial tone to make calls and can't receive calls. The handsets don't ring when there is an incoming call. I tried plugging the base station into another telephone socket but it didn't work, I briefly got a "no signal" message on the hanset screen. The handsets are still named and have phone book access. all handsets have a red flashing LED.
    I also have a BeoCom 4 which works fine but i want the two systems working off the same telephone number, I don't need the two systems to intergrate, just all 4 phones working. The BeoCom 4 is plugged into the same socket as the as the internet router.
    Any ideas about the BeoCom 6000 base station problem or advice would be greatly appreciated.
    Michael.
  • 10-05-2011 3:24 AM In reply to
    • valve1
    • Top 500 Contributor
    • Joined on 05-27-2009
    • Dublin Ireland
    • Posts 213
    • Gold Member
    Re: BeoCom 6000 no dial tone - no signal
    Have you any way to prove you have dial tone going into the bc6000 base ? I see no reason the bc4 would not work as a hard wired extension from the base station socket.
  • 10-05-2011 7:03 AM In reply to
    • Beeme
    • Not Ranked
    • Posts 2
    I assume because my BeoCom 4 is working fine with a dial tone that there must be a problem with no dial tone "coming out of" the BeoCom 6000 base station. Unless the cable that is hard wired into the BeoCom 6000 base station is damaged. I suppose I just need to take it to B&O and ask them to look at it - Boring!
  • 10-05-2011 12:08 PM In reply to
    • valve1
    • Dublin Ireland
    • Posts 213
    • Gold Member
    Beeme:
    Thats where you should check first, try the bc4 there before packing all you kit off to get tested.
