Dear Forum,
I got a Beovision MX 4000 Type Nr. 7870, sw 3.1 that I attached via Aux.Link to the Beomaster 7000.
The speakers (Beovox 5000) are connected to the Beomaster.
It works as described here:
But: the volume of TV sound is much lower than the radio/cd sound...
TV volume need to be set up to appr. 40 to be equal to 20 if listening to the radio.
Due to this, ff you watch TV and change to Radio, the sound is very loud.
How can this be changed? Any ideas/hints?
Thanks!
Ralf
PS: I wonder why the AV button needs to be used. With Masterlink if worked different as far as I can remember. Might be because speakers were attached to the Beovision Avant, not the audio system (Beosound 3000).
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
