Just going over a beogram 1203, and the arm functions do not work. The coil on the relay assembly underneath the turntable reads open circuit. The Relay is manufactured by Varley and the coil is marked V2/M/90R V11.  Anyone know what kind of relay could serve as a replacement, or could be used for a replacement coil?
Many thanks,
John Orme
