Latest post 09-21-2011 11:38 AM by Leslie. 4 replies.
Page 1 of 1 (5 items)
  • 09-21-2011 9:49 AM
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Quick Beosound 1 Question..
    I'm contemplating purchasing a used BS1.  It's described as having some minor dents in the front grill.  If I remove the grill would it be possible to push out the dents from the inside?
    Thanks in advance.
  • 09-21-2011 10:37 AM In reply to
    Re: Quick Beosound 1 Question..
    Yes, you can remove. Use a WOOD BALL (you can found in a brico store for 1 Pounds) and put grill on wood table.
    Remember to remove black interior (is very simple, it isn't fix).
    After remove sign on grill you can re-paint.
    I have repaint in MORE color and whit UK flag.
    Photo:
    Beosound 1 Union Jack
  • 09-21-2011 10:38 AM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    The front grill is aluminum, and it does come off.  Therefore, it would not be difficult to push the dents out from the inside.  However, the final results really depend on how bad the dents are, if there are scratches that go along with the dents and how good you are with metal working.  You might also consider finding a replacement grill - these come up on eBay from time to time... although I've never much paid attention to the price - so I don't know if they're considered repair parts or rare and exclusive collectors items Smile
    Stan
  • 09-21-2011 11:18 AM In reply to
    • mediabobny
    • Posts 336
    Stan:
    Thanks.  That's exactly why I'm asking if the dents can simply be pushed out.  Yes -  thumbs up
  • 09-21-2011 11:38 AM In reply to
    November35:
    Photo:
    Excellent job November35Yes -  thumbs upYes -  thumbs up, especially the UK flag (or not Graham?)Whistle
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
