Hi Folks,
I just bought a used floor stand for my Beocenter 2. It doesn't have the small pikes at the bottom, but that was not a real problem. What is a problem is the 2 screws that attach the Beocenter 2 to the floor. They are the original one but it was not possible to tight them completely. It lacks 2 mm to fully be tighted to the Beocenter 2 unit.
Do you have the same issue? Is it a problem with mine?
Thanks ;)
Sergio
