Some Beovox 4702 (and 4703) came with foam surrounds (that rot), but a few had rubber (that doesn't).
Some speakers even came with mixed foam/rubber woofers.
I suggest you check the other three woofers.
S30 woofers are very different and can't be used for the 4702 but I have some good
used original 4702 woofers with rubber surrounds if you need. PM me for details.
