Hi again,
Thanks for the additional information. Checking other posts on the subject of P45s, I notice an earlier one from you on problems with a pair of P45s, which I assume are the ones you are selling. I quote -
"i bought a pair of P45 speakers on Ebay but unfortunetly one of them not working properly it plays only high freqency sound. i thought that it maybe crossover but i dont know how to check it. can enyone help or is there anybody in Warwickshire who can fix it?
This is a common problem with the bass drivers of the P45 - how did you fix it?
Have a good holiday, by the way.
Cleve
