Latest post 08-05-2011 4:13 AM by jahur. 7 replies.
Page 1 of 1 (8 items)
  • 08-04-2011 12:03 PM
    • jahur
    • Top 500 Contributor
    • Joined on 02-07-2011
    • planet zonk
    • Posts 161
    standby and go light hand in hand
    may have a problem... my beocentre 2300 has its standby light and on light on together, have only just noticed this.
    is the beocentre trying to tell me something?
    (formerly nokinnikon from the old site)
  • 08-04-2011 12:48 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: standby and go light hand in hand
    jahur:
     I assume it's a green LED that is making you uncertain - your BeoCenter tells you "Timer has been activated"
  • 08-04-2011 3:25 PM In reply to
    • jahur
    • planet zonk
    • Posts 161
    agh i see, ill brain my 9yr old! i will get to it and check it out, manual time again!
  • 08-04-2011 4:54 PM In reply to
    • jahur
    • planet zonk
    • Posts 161
    ok i have pushed many 'a' button and checked the manual and cannot find any reference to a timer function.
    anyone else help???
  • 08-04-2011 5:46 PM In reply to
    • Vienna
    • Posts 712
    Early BeoCenter 2300 with Ser# < 11346600 or 11491838 (depending on the market)
    and SW lower than 1.3 were IR two-way capable.
    Timer-programming was only possible using a two way BeoLink 5000 / 7000.
    SW 1.3 did block 2-way support and later on, from Ser#1281331 the PCBs have
    also been redesigned without 2-way components.
  • 08-05-2011 2:56 AM In reply to
    • jahur
    • planet zonk
    • Posts 161
    wow vienna, thats a very comprehensive reply. even so its not made me any closer to sorting it out. my beocentre is the version where the lazer goes up and down as opposed to the meandering lazer. in fact im going to look at the servie invoice to get the details as i dont have time to wrench it from its perch and ascertain the type no/serial number.
    ok vienna, the serial number is- 14525338, hope this helps.
  • 08-05-2011 4:03 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Did you see this?
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 08-05-2011 4:13 AM In reply to
    • jahur
    • planet zonk
    • Posts 161
    that makes a lot of sense. danke bitte.
    jason
