Latest post 07-25-2011 1:03 AM by Heribert. 7 replies.
Page 1 of 1 (8 items)
  • 07-23-2011 5:40 AM
    Sound Setting on BL2000 possible?
    Dear all,
    I have a Beolab 2000 and like it a lot. But I would like to have more Bass on it. It sounds a little thin in comparison to my other speakers (BL3 and BL6000). Especially noticable when all speakers are on and I walk through the house.
    Any ideas how I could change the Bass/Treble setting?
    Thanks, Heribert
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
    Filed under:
  • 07-23-2011 7:49 AM In reply to
    Re: Sound Setting on BL2000 possible?
    hello
    Unfortunately, the bass and treble adjustment of the factory can not be produced in this way, but a speaker with very good sound regards
  • 07-23-2011 2:48 PM In reply to
    • SWISS_2
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Heribert;
    I too thought of this last year when we upgraded from a Beosound 3200 to a Beosound 4.
    We wanted a bit more bass with the sharper digital notes from the Beosound 4.
    It is pre-set, just like the Beosound 1. No luck, but it remains a very clever, good speaker.
    • SWISS_2
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Heribert;
    We also tried adjusting the sound inside the Beosound 4 without much effect on the Beolab 2000.
  • 07-23-2011 2:53 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Was there not a thread a couple of years ago re pcb changes to achieve this?
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 07-23-2011 4:08 PM In reply to
    The only thing you can do is changing each driver's volume settings in the service menu, meaning you increase the woofer's volume to +2 dB and /or decrease the tweeter's volume by - 2 dB, this will of course change the factory settings but will give you more audible bass , but not lower frequencies.
    Of course, placing the BeoLab 2000 in a corner will also greatly increase the audible bass levelStick out tongue
    Reunion Island is greeting you!
  • 07-23-2011 5:37 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Chrisreunion:
    Absolutely true -  compared to a "freestanding" position:
    - mounting a speaker "flat" on a wall will increase bass output by approx. 3 dB
    - mounting in a corner of 2 walls OR a wall and the floor/ceiling will increase bass output by approx. 6 dB
    - you'll gain 9dB if placing a speaker close to floor/ceiling AND 2 walls.
    ... small speakers like CX 50/100 or BLb 2000 will sound completely different!
  • 07-25-2011 1:03 AM In reply to
    Chrisreunion:
    Hi Chris,
    How can I access the service menue and then how to change the setting?
    Thanks,
    Heribert
