Latest post 07-19-2007 8:47 AM by Piaf. 2 replies.
Page 1 of 1 (3 items)
  • 07-18-2007 11:00 PM
    • Piaf
    • Top 150 Contributor
    • Joined on 07-08-2007
    • Victoria, British Columbia
    • Posts 409
    Needed part for a Beogram 4000
    I am looking for a replacement white plastic bearing (Part #2905034) for my Beogram 4000. This bearing secures the spindle at the end where the drive motor is attached via a belt.
    Thanks!
    Jeff
  • 07-19-2007 3:10 AM In reply to
    Re: Needed part for a Beogram 4000
    Probably easier to get one made - someone with a lather and some good measuring tools can probably make you one for relatively little cost. A friend of mine has made bits for me!
  • 07-19-2007 8:47 AM In reply to
    • Piaf
    • Posts 409
    Thanks Peter,
    I already did that with "original" B&O plastic from a Beogram 8000 "parts" turntable. My copy is essentially the same as the original, but I thought the real deal might be better in the long run. Plus it never hurts to ask.
     Jeff
