Hi Martin and thanks for the welcome message.
I have half solved the problem, after receiving a pm from Menahem in Israel. He suggested holding down the black ring in the middle of the platter and rotating the platter a few times. It didn't want to do this, but with a bit of force, this made the arm move back to its start position. Now, when I press play, the platter rotates, and the arm is mechanically moved to the start of a record. I HAVE SOUND - but not for long. The record plays for about a minute, then no more, it gets stuck in the same groove. The arm obviously does not track. So, now onto getting the arm to track.
If I listen very carefully, when the arm moves to a certain angle from 90deg, I hear a motor start. Now, after taking off the platter, I think it is a motor on the back left of the player. I can feel it vibrate, but nothing happens. It looks to me like there should be a belt on there, that goes diagonally to a pulley at about one o'clock. But there is no belt on it.
So:
1. Should there be a belt there?
2. Does this belt work the tracking (a very clever idea if it does)?
3. Where do I get a belt? I live in Denmark, so might be able to get one quickly, but don't know where to look. Where do you source things like this?
I have had a good look around everywhere inside the machine, and I cant see a broken belt, or one that has hopped off.
This forum is just great. From utter desperation earlier today, I have a glimmer of hope.
Kind regards
SimonC
