Latest post 06-09-2011 1:44 AM by Cleviebaby. 3 replies.
Page 1 of 1 (4 items)
  • 06-08-2011 1:27 AM
    Beovox 1702s in Rosewood for sale
    I have a pair of Beovox 1702s in Rosewood for sale.  The veneer is beautifully figured and apart from a very slight bang to the alluminium trim that you wouldn't notice unless you were looking for it, are cosmetically excellent - nearly mint in fact. The surrounds to the bass/mid-range units are rubber so no foam rot to worry about.
    From a power handling and period point of view, they would be ideal with a Beocenter 1400/Beomaster 901/Beomaster 1001, although they would be equally at home with the much later 1400/1500 tuner/amps or similar Beocenters.  In fact I've used them with a Beomaster 4400 as both main and ambio speakers with no problems and even on the end of a Beomaster 8000.  They are efficient enough to go pretty loud with very little power.
    They are much warmer and easier to listen to for long periods than the CX series.
    I would post photos, but the file size is too big.  If anyone can advise me how I can reduce the file size, I'll pop on some pics.
    30GBP plus postage or collect from Exeter
    Cleve
  • 06-08-2011 4:36 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Beovox 1702s in Rosewood for sale
    if you're using windoiws , open the paint facility, open the file in paint and resize it, i usually use 25%, gives a bhandlable image which should load easily on here
    saLUT
    TONY
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 06-08-2011 3:28 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-11-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 06-09-2011 1:44 AM In reply to
    Thanks to you both - I'll play with the options later.
    Cleve
