Latest post 07-19-2007 6:37 PM by The Plumber. 5 replies.
Page 1 of 1 (6 items)
  • 07-19-2007 6:16 PM
    Dimensions of BV5
      Could somebody tell me the dimensions of a BeoVision 5 as in, Height, Width and Depth on easal stand. Centimeters or Inches are fine.
    Im trying to persuade SWMBO on where i want to positon a BV5, so plan on making a wooden BV5 at the correct dimensions to show her that im right.
    Cheers.
    Never Mind The Ball-Cocks www.markmossplumbing.co.uk
    A labourer uses his hands
    A tradesman uses his hands and his head
    A craftsman uses his hands, his head and his heart
  • 07-19-2007 6:26 PM In reply to
    Re: Dimensions of BV5
    Hi here are the spec. of this wonderful TV Smile
    Dimensions W x H x D
    (Dimensions W x H x D incl Wall bracket
    (Dimensions W x H x D incl motorised stand
    (Dimensions W x H x D incl Floor Stand
    (Dimensions W x H x D incl Cabinet
    1066 x 1150 x 170 mm
    1066 x 1150 x 202 mm
    1066 x 1205 x 558 mm)
    1066 x 1190 x 340 mm)
    1066 x 1370 x 380 mm)
    Weight76 kg
  • 07-19-2007 6:27 PM In reply to
    Cheers Stig. Im a big fan of yours.
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    All in the products section under technical specs.
    Here you go!
    Lee
    PS - If she doesn't let you have one, you could always stand the wooden one in the corner as a protest! Laughing
  • 07-19-2007 6:34 PM In reply to
    Glad to help
    That Lee what a comedian Laughing Laughing Laughing Laughing
  • 07-19-2007 6:37 PM In reply to
    As soon as i posted the question, i thought, oh, i bet its in the products section. Thats me though, speak before i think Smile
