1st March February 2012
Latest post 07-26-2011 1:25 PM by macjonny1. 8 replies.
07-22-2011 2:10 AM
Wings
- Joined on 04-17-2007
- Hong Kong
- Posts 341
Dear All,
I have the opportunity to buy a BL 7000 with table top charger for 540 Euro [475 pounds sterling]. Obviously, depending upon condition and perhaps age, is this a reasonable price [assuming good cosmetic condition and fully functional]?
Thanks in advance for your comments / advice.
Wings
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
300 to 400 Euro max. in my opinion....
Check ebay prices to get an idea.
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Sounds high... But then again, depends on the rarity of the item in your area, and how important a face-2-face deal is compared to buying online?
I got mine for 250 euros 10 years ago. But in the 10 years I expect them to have gotten more rare...
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
Wings
- Hong Kong
- Posts 341
Thanks, all.
This will be a local purchase, so I will be able to inspect and perhaps test the BL 7000 before purchase. Also, no worries about damage during shipping from overseas.
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Wings: This will be a local purchase, so I will be able
That's
worth quite a bit of course - but still I think it is way overpriced
unless it really is flawless. Try to haggle it down. fleaBay has been full of these lately, so
rarity is not an issue at least in global context.
Try to test
two-way functionality from a good distance, not just on the same table
with the controlled unit (if you get NO CONTACT further away, you'll be
looking at repairs soon). Also, try to find out if the battery will hold
charge for any reasonable time; probably need to trust the seller on
this...
Wings
- Hong Kong
- Posts 341
Mika, thanks. I did check e-bay but there is only one functioning BL7000 listed. There is another listed as for repairs or parts as the seller is uncertain whether it is working. I did not see any listed on LifeStyle AV.
I will see what the seller here in Hong Kong wants for a bottom price.
Jonathan -- thanks to you too. One reason for considering this purchase is so that I can have a spare [for use or for repairs] should my present one go on the blink. My Beogram 7000 is still down as I do not have much time to work on it at present. The Beomaster 7000 is showing signs of impending problems with the capacitors [?] and the Beolab 4500 needs work.
Fortunately, in my old age, I think I am holding up better than my B&O! Ha, ha, ha.
BTW: It might be the same person selling a Beolit 400 for HK$4,000 [~356 Euros]
macjonny1
- Joined on 11-08-2009
- Posts 355
I think the response was reasonable because there will certainly not be any BL 7000 going for just $107 in the end of the auction.
Anyway, I currently have (located in the USA) a Beolink 7000 that is in perfect working order with table charger that I would let go for what I paid for it at $475 USD plus whatever shipping is. Currently my BS9500 is in a different room so it is getting lonely without that fabulous 2 way communication. Remote was recently serviced before I purchased it. It has hardly been used since I have. Holds charge well, motor works great, 2-way works fine, etc.
Page 1 of 1 (9 items)
