Latest post 11-04-2011 1:37 PM by Medogsfat. 1 replies.
Page 1 of 1 (2 items)
  • 11-03-2011 6:58 PM
    • johpa
    • Not Ranked
    • Joined on 11-03-2011
    • Posts 1
    Beocenter 2200 Audio Input
    Hello,
    I have a Beocenter 2200 that I would like to connect to an external audio source (CD, iPod, Computer etc.)
    Now it appears that it does not have such an input, only an output for an external Beocord. Is there a way to use this interface as an audio input?
    Or is it somehow possibly to modify or "hack" the Beocenter and add an input?
    Thanks a lot in advance
    Joh
  • 11-04-2011 1:37 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beocenter 2200 Audio Input
    There is a 5 pin DIN AUX/tape 2 input on the FRONT edge (you probably made the mistake of expecting it to be at the back with all the other connections - that would be far too sensible) which can be used to connect any other audio device to. Chances are you will also need a 5 pin DIN/RCA (phono) converter cable but these are readily available for not much money.
    Chris.
