Latest post 04-26-2011 4:28 AM by stotty1111. 1 replies.
Page 1 of 1 (2 items)
  • 04-25-2011 2:11 PM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    BL 5000 will not fire up
    Seem to have a problem on board 8001032 board 3 in the service manual as the screen boots to indicate source but no volume ie as if muted - tried swapping to other unit same situation, thus, the problem is on here seems as if the amp board relay is not tripping - after a long day messing about, anybody any ideas, is the relay controlled by one of the bc547's or one of the surface mount jobs
    help
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 04-26-2011 4:28 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: BL 5000 will not fire up
    The other unrepaired display is now not working properly, the backlight works, but no display info - suggestions or is it a replacemenbt job(if i can source one)?
