just saw this, luckly there is a photo of underneath which shows the serial number somehow went walkabout with the socket box,
first one to guess the sellers answer when i ask why its been removed
jason
theres no link
Yes that would be useful
http://cgi.ebay.co.uk/B-O-Beocenter-2-Master-Unit-/260773160900?pt=LH_DefaultDomain_3&hash=item3cb74aa7c4
his grandad didnt like labels?? This unit is local to me!
i dont know if anyones ever told you but you look a little like 'ba baracus' , i recon you can handle yourself if it goes bad
well unless you you have to get on a plane, but if hes near you should be alright
if you saw me and Mr T stood together you would struggle to tell us apart!
I pity the fool
"it came off in the wash"?
If you think nobody cares, try missing a couple of payments.
the dog ate it?
A few scratches...Socket unit was "lost"...Sold without cables etc...Hmm...
Best regards
Spiros
Should this be reported to eBay?
Peter : Should this be reported to eBay?
He does have a positive previous history of selling B&O though this is strange as his selling history shows him as based in USA, UK and Lithuania!
Still wouldn't touch it with a barge pole.
My bet is you get no reply from him.
Chris.
From: iconic-avTo: accordsportsSubject: Other: iconic-av sent a message about B&O Beocenter 2 Master Unit #260773160900Sent Date: Apr-22-11 11:14:03 PDT
In which case no PIN so useless. Only useful if the acquirer didn't scratch it when 'lifting' it.
Do I assume that items like this will have a built in code that can directly trace back through to the warranty?
I would hope this is the case/
I think there will be a serial number inside - However in this situation, I cannot see any dealer being happy to touch this.
