        1st March February 2012
	    Latest post 04-23-2011 2:47 AM by Spiros . 36 replies.
								    |  04-12-2011 10:36 AM |  |
									                 egohJoined on 04-12-2011Austin, Texas - USAPosts 77 |
										    Hi folks, I recently acquired a Beomaster 4500 and Beogram CD-4500 in non-working condition. The Beomaster was an easy fix and just needed a new capacitor in the power supply. The Beogram CD player only outputs white noise and a bit of screeching sound. The servo stage seems to work fine, as well as the display, output relays, etc. I changed the 4700uf and 2200uf caps since they were likely suspects but no change. I'm assuming a cap near the DAC is probably shot. I don't have the service manual for this so I'm a bit in the dark. I've been trying to trace the circuit board but it's been a bit difficult to figure out. Any suggested areas to look at? At a later date, I'll change out all the capacitors on both units, but I'd love to get it working first. I'm also working with a local metal shop to have replacement mirror panels fabricated. My fingers are crossed that it works out well. :) I'll post pictures once it's all done. Thanks in advance! |  |
									                 Evan
 Joined on 12-15-2008Ohio | USAPosts 2,601 |
										    Welcome to Beoworld! You are well on your way to a wonderful set of Beo    I gave up on the mirrored panels and decided to paint mine instead.   As far as circuit diagrams and the like go, they are available through the site to Silver and Gold level members. |  |
									                 burantekJoined on 05-04-2007SE USAPosts 6,214 |
										     Evan:As far as circuit diagrams and the like go, they are available through the site to Silver and Gold level members.
 Unfortunately, neither the CD4500 service manual nor its closest relative, the 3500, are on site -yet. Perhaps the service manual to another CD player with similar technical guts could be suggested, if on site? |  |
										    Thanks for the welcome Evan! I saw your thread on painting the panels. Looked very nice. However, I really took the plunge and removed the existing panels (and added some damage to them). So, I have to figure out a replacement.  I'm working with a local shop that is cutting and bending stainless steel mirror finish panels. Should look the same, except the color will probably be a bit different since it's not going to be aluminum.   I'm also having new metal bent (brushed steel) for the Beovox 3000 passive speakers I picked up at the same time.    |  |
										    Thanks burantek, that's too bad that the manuals aren't available. I'm browsing the 5500 manual and see some similarity.  I saw this thread: http://forum.beoworld.org/forums/t/37702.aspx Seems to be a similar problem. I replaced all the 100uf caps and the white noise is gone. However, now I have no output. Going to poke around some more but I think the blown cap. might have taken something else out as well. |  |
										     egoh:
 Definitely
 post some pics, esp of the BV3000 panels. I, and a lot of other folks,
would surely be interested. The mondrian panels as beautiful as they are
 -are notorious for blemishing by just being looked at wrong. Oh, and welcome to BeoWorld as well! |  |
									                 Leslie
 Joined on 05-07-2009NetherlandsPosts 2,201 |
										     egoh:I'm also working with a local metal shop to have replacement mirror panels fabricated. My fingers are crossed that it works out well. :) I'll post pictures once it's all done.
 Please do! I'm doing the same with a company in the UK. The bending is not what they do unfortunately.... B&O item 1, B&O item 2, B&O item 3,...................B&O item 735 Beovirus? What's that? |  |
									                 Evan
										     burantek:
 Whoops! My mistake! I was trying to post right before class started so I didn't check.    |  |
									                 Evan
										     burantek:The mondrian panels as beautiful as they are -are notorious for blemishing by just being looked at wrong.
 DITTO. At the moment I am dealing with some old (~6 months) fingerprints left over from installation that I forgot to wipe off when I finished!  |  |
										    OK, CD player is working great again. I used the 5500 schematics to figure out the problem. The 100uf caps in the opamps need to be replaced. They are C103, C109 (? the screening is reversed and hard to read so I'm not sure of the number), C107, and C106. Also R121 (68 ohm)blew as a result of the shorted cap(s).  I'll keep everyone posted with the cosmetic parts fabrication. Hopefully by the end of the week. |  |
									                 Steffen
 Joined on 06-24-2008DenmarkPosts 281 |
										     Evan:
   Yes -sometimes it's not enough to use ordinary cleaning products. I use Sterling Stål Blank (steel cleaner) for my BL 5000 and Penta's (it must be without abrasive effect).It is very effective. I don't know if you can buy it in the States -but there must be something similar.
 Steffen |  |
										    As promised, here are the photos of the Beovox 3000 (4500) restoration project I finished. Before:
 Removed Stainless for pattern:
 Fabricated panels (one with protective plastic still on):
 After:
 Beomaster 4500 mirror fabrication still in progress... |  |
										    Here is another photo with flash:
 Overall, I'm quite happy with the results. The stainless was a bit thicker than the original, so it's more durable. However, it's also harder to bend so there is some light rippling at the bends. Not bad for my first B&O cosmetic restoration.  |  |
									                 Leslie
										      Well done!  Btw, the Bang & Olufsen text on the Beovox flatpanels is originally not engraved. To much cleaning and you wipe it off This what I used and it (almost) looks the same as the original!   B&O item 1, B&O item 2, B&O item 3,...................B&O item 735 Beovirus? What's that? |  |
									                 Leslie
										    No Egoh, just the logo. Bought the metal (mirror finish) sheets already for both Beovox 3000 and 5000 but now I'm looking for someone who can do the bending of the sheets (90 and 135 degr. angle). The bending radius must be a "sharp" as possible if you know what I mean. B&O item 1, B&O item 2, B&O item 3,...................B&O item 735 Beovirus? What's that? |  |
									                 Leslie
										    Okay, I understand. How much is your sheet thickness? Mine is .5mm (Gauge 23, .023") B&O item 1, B&O item 2, B&O item 3,...................B&O item 735 Beovirus? What's that? |  |
									                 Medogsfat
 Joined on 02-21-2007*Moderator* Leeds, YorkshirePosts 4,045 |
										    A press brake will only give a clean line if the blade actually meets the "V" in the base of the former which won't normally happen in angles of less than 90 degrees. A much better option for this would be to find someone with a good old fashioned hand operated sheet metal bender where the sheet is clamped & just one side bent against an edge. Egoh is correct - the thicker the metal the less chance of a sharp edge. In tight tolerances you also need to take the thickness of the metal into account when cutting for size. The thickness of the metal needs to be deducted from the overall measurement for each fold of 90 degrees or more. Chris. The use of metaphors should be avoided like the plague. They're like a red rag to a bull to me. |  |
									                 joeyboygolf
 Joined on 04-16-2007Ely, Cambridgeshire, UKPosts 3,252 |
										    barrie911 on  ebay tells me that he does replacement panels for Beovox 3000/4500/5000 which are made from the same type of stainless as original and he has also sourced transfers in the correct type face. I have not seen them! Perhaps one of you should contact him, it may save you time and money. |  |
										    Leslie, I'm not sure of the gauge and it's hard to measure now since it's mounted.  Medogsfat, thanks for the info. Helpful stuff for when I have my Penta panels fabricated. |  |
