Latest post 12-21-2011 2:18 PM by stefan. 5 replies.
Page 1 of 1 (6 items)
  • 12-20-2011 5:35 PM
    Ouverture and ML/MCL ??
    I'm trying to help a friend with his B&O setup.
    He owns an Ouverure which he uses with a pair of Beolab 6000 and a Beolink 1000 controller.
    He now wants to set up sound in a second room using a ML/MCL connected via Masterlink + using a X-tra speaker kit. We have light in the IR panel, and the mute button makes the relay click in the X-tra box, but nothing more???
    Any guidance from the Beoworld would be much appreciated.
    Cheers
  • 12-21-2011 6:10 AM In reply to
    • Guy1680
    • Top 500 Contributor
    • Joined on 08-18-2007
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    Re: Ouverture and ML/MCL ??
    Have you checked all the MCL wiring?  That was the problem with the set up at this link: http://forum.beoworld.org/forums/t/41582.aspx
  • 12-21-2011 6:42 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Pressing the MUTE button should activate your Ouverture.
    Does the light flash, if you press a button on your remote control? Beo4? BL1000?
    Did you check the option setting? Should be set to L.OPT 1 or 2.
    Stefan
  • 12-21-2011 1:25 PM In reply to
    Thanks,
    Will re-check the wirering next time.
    In this case, there is no reaction at all to the BL1000 at the transciever - not even a flickering in the LED. Only when pushing mute on the panel there is a reaction in the relay in the X-tra box.
    We have had the speakers connected directly to the ML/MCL and the masterlink to the Ouverture, no sound from the extra speakers at all - should there have been any sound ?
    Can the ML/MCL be faulty ?
  • 12-21-2011 1:29 PM In reply to
    We tried different combinations of Link 1 / 2 and Store, directed to the Ouverture, nothing happend. Guess I will have to consult the Ouverture manual for additional info to understand how to setup?
  • 12-21-2011 2:18 PM In reply to
    • stefan
    • Posts 1,733
    Sorry. You have to direct option setting to MCL in the link room.
    Press LINK - 1 - STORE when directing the BL1000 to the IR eye of the MCL. It now should flash.
    Stefan
