I've just purchased a very nice MX4002 from Lifestyle and was wondering how I can remove the external screen to clean inside.
The manual only suggests to contact a B&O dealer.
There are some particles right in the centre of the screen which are visible when on. Also how can I turn the video off leaving audio only?
With my MX7000 I press PICTURE+MUTE with the unit on or AV+[Source] with the unit off. It doesn't work with the MX4002.
I've tried both the beolink 1000 MKI and the BeO4 with no result.
Any suggestions please? If you have a diagram even better
Many thanks
