The reproduction rubber clutch washers are fairly new reproduction and I'm working
on instructions for replacing them in the Beomaster 1600 & 1700.
Hopefully I will soon have something ready with text and photos.
A new clutch spring with a bit more tension is also being reproduced, currently undergoing prototype testing.
Anyway, you need to take off the whole panel, that's 4 screws and two connectors, and carefully
free it from the traction roller.
Then remove the tiny spring at the side of the clutch casing.
Free the four flat pulling strings from the sliders.
Remove two round springs, one each end of the clutch casing.
Then you can take the casing apart.
For a start, you can swap the volume (leftmost) rubber washer with one of the others (that saw much less use).
That may buy you a little friction but of course it's neither a perfect nor a lasting solution.
For lubrication, you can spray in a little contact cleaner of the type that also contains a hint of lubrication but
usually, a good cleaning with cotton buds and contact cleaner will losen up things well.
It's an akward place to reach, the panels don't come apart any more than this and you may find that pipe cleaners
work better than cotton buds because they can be bent in suitable angles.
I've never seen WD40 do any good in any B&O. It's good for use on rusty cars though and that's where I use it.
