Latest post 03-21-2011 6:19 PM by Søren Mexico. 2 replies.
Page 1 of 1 (3 items)
  • 03-21-2011 5:04 PM
    • NYmike
    • Not Ranked
    • Joined on 03-21-2011
    • Posts 1
    Beogram 1800
    I have the service manual and yet to tackle it head on - any suggestions as to specifics for this suddenly arisen issue?  Tonearm cues when play hit, then as it sits to the intro groove, slides off to the right and sits there.  Any specific adjustments to the cueing mechanism that can easily addressed?
    Cheers,
    Mike
  • 03-21-2011 5:34 PM In reply to
    Re: Beogram 1800
    I had a Beogram 1902 doing the same thing. I didn't find the problem source, but I suspect that the "arm lowering" lever got stuck under the mechanism.
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 03-21-2011 6:19 PM In reply to
    Re: Beogram 1800
    Check the manual, there should be two exentrics to ajust the set down point for 17 and 30 Cm records, but before ajusting clean and lubricate.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
