Latest post 03-05-2011 2:49 AM by siriceman. 4 replies.
Page 1 of 1 (5 items)
  • 03-03-2011 3:24 PM
    Beolink 7000 - some keys not working
    Hello!
    I have a Beolink 7000 and about half of the keys are not working. The battery is new and everything else is working ok.
    Is it possible to repair this, maybe by myself? I would appreciate some hints Smile
    THX
    SirIceman
  • 03-03-2011 4:08 PM In reply to
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    Re: Beolink 7000 - some keys not working
    Do you mean those red buttons or the "blue ones" (the touch-screen)? What does work and what doesn't?
    I have noted that some of the touch-screen buttons (especially the center of the screen) need a bit more pressing in my BL7000. I would suppose that to be pretty hard to fix, I wouldn't dear to fiddle around with the screen...
    Bang & Olufsen - The art of controlling sound, picture and light
  • 03-03-2011 4:35 PM In reply to
    what i could test so far controlling Beomaster 7000, this red keys do not work: 0,2,4,5,6,8, Sound, Clock, Light, <, >, Mute
    and this touchscreen keys do not work: Setup, <Search,
    Greetz
    SirIceman
  • 03-04-2011 5:19 PM In reply to
    Did you take off the glass panel in a repair? It could be that it is not mounted properly and that the goldplated springs do not touch the glass panel any more, and in that case the keys don't work.
  • 03-05-2011 2:49 AM In reply to
    i don´t took off the glass panel and as far as i know the remote was not repaired before.
    So do you think it´s worth a try to take the glass panel off an remount it. I think there is no service manual available for Beolink 7000, so i´m not really sure how to disassemble it.
    Greetz
    SirIceman
