Latest post 03-04-2011 12:44 AM by hagan. 4 replies.
Page 1 of 1 (5 items)
  • 03-03-2011 6:22 AM
    • NEM1
    • Not Ranked
    • Joined on 03-03-2011
    • Posts 2
    BeoVision 10
    I have recently had a BeoVision 10 46" television installed at home, upgrading from the Avant TV.  However, it was a surprise to find out that the clock no longer displays on our BeoLab 3500 speakers around the house and they no longer turn off automatically. The supplier has informed me that the Avant used to have a clock inside it. However, the BeoVision 10 does not.  Bang & Olufsen has apparently confirmed that there is nothing that can be done about this. The only option is to install an audio source on the system (which I do not have) that has a clock in it or keep the Avant on the system.
    Has anyone else experienced this problem or found a solution?  Is there a software/hardware update for the Beovision 10?
  • 03-03-2011 6:24 AM In reply to
    Re: BeoVision 10
    The solution is to repurpose the Avant in another room. Otherwise there are some good deals on audio masters.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 03-03-2011 6:40 AM In reply to
    • NEM1
    • Not Ranked
    • Posts 2
    Re: BeoVision 10
    Thanks, what is an audio master?
  • 03-03-2011 10:22 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: BeoVision 10
    Bang & Olufsen audio system.
    Choose from: BeoSound4, BeoSound3200, BeoSound9000, BeoCentre2. Or pick up a pre owned model such as BeoSound3000 or BeoSound Ouverture.
    BeoSound3200 just discontinued so you may pick up a bargain from your local dealer.
    Opman
  • 03-04-2011 12:44 AM In reply to
    Re: BeoVision 10
    I have a setup with Beosystem 7000 + BV10 + Beolab 3500.
    At first clock showed on bl3500 but after changing time in Beomaster with MCP 5500 clock disappeared and has never showed since. Before I used Beolink 5000 to set time but it´s broken.
    strange...
