Latest post 02-28-2011 5:51 PM by Step1. 4 replies.
Page 1 of 1 (5 items)
  • 02-27-2011 10:44 AM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    MK1/2 Beolink 1000 Keypads.
    Does anyone know where I can get MK1/2 Beolink 1000 keypads from? There was someone on Ebay who used to be able to supply them. Just checked and they don't seem to be registered anymore.
    CraigSmile
  • 02-27-2011 11:17 AM In reply to
    • Craig
    • Posts 4,855
    Re: MK1/2 Beolink 1000 Keypads.
    Jusst been back through 7 years worth of my feeback and found them. They are still listed, I just had thee name slightly wrong.Embarrassed
    CraigSmile
  • 02-28-2011 4:38 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    I repaired mine using a special conductive rubber paint (not the silver stuff which is not suitable) but I don't know where you get the stuff from anymore, as it seems to be discontinued!
    Olly.
  • 02-28-2011 1:34 PM In reply to
    • Craig
    • Posts 4,855
    Step1:
    You can get that from car spares shops. It's used to repair heated rear screens. What I was looking for, is the actual rubber keys. You can get the later MK3/4/5 ones from B&O as a spare part.
    CraigSmile
  • 02-28-2011 5:51 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Ah sorry Craig I thought you mean't the conducting strip behing the keys! I have never used the silver stuff I doubt it is flexible enough tbh. I can imagine it breaking away and leaving debris to short tracks etc... I might be wrong though!
    The stuff I use us rubber carbon based specially designed for remote repairs. Like I said can't find it anywhere in the UK these days!
    Olly.
