Latest post 02-26-2011 5:51 AM by OKF. 0 replies.
Page 1 of 1 (1 items)
  • 02-26-2011 5:51 AM
    • OKF
    • Top 500 Contributor
    • Joined on 02-22-2008
    • Posts 204
    BV 10 and System Dock (i-port) integration
    I have got the so called 'System Dock' which is a third party device from iPort.
    I would like to use it with my BV 10 which comes mid of March. I would like to use via the IR option so it needs linking with a cable to the TV. I have tried it with my old 7-40 but I can only get it working through the build in IR eye of the dock when I incorporate the Apple remote into my Beo 5 remote. My dealer tells me that this is right because the TV needs the propper Software which the BV 7 cannot have and the BV10 will have it and then I would chose the FS-23 in the STB Menu and it would then work properly. Can somebody confirm this? Does somebody have the Iport or cansomebody look up his BV10 Menu whether he can find a FS-23 or Iport FS-23 or System Dock.
    Also what about the Beo 5 what would I choose there?
    Best regards Oliver
