Latest post 02-11-2011 12:29 AM by nycbrg. 5 replies.
Page 1 of 1 (6 items)
  • 02-09-2011 7:45 PM
    Beocord 8002 etc keypad cover
    Anyone have a creative fix for a operating panel that has the majority of it's plastic pc retaining clips broken? I guess more pressure when the key doesn't work is not always the answer!
    Brian
    BeoMaster 8000, Beogram 8000, Beocord 8002, Beogram CD50, M100's.
    Beocenter 9500 Beovox P45's
  • 02-10-2011 2:45 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Re: Beocord 8002 etc keypad cover
    I did have a think when servicing my keypad, as three of the clips were broken, but it wasn't enough of a problem to give it a great deal of thought!
    I might go back to this because I would like to replace the switches altogether, you can hardly feel the tactile response from some of the switches, which I suspect is very similar to along with the cause of your situation!
    Olly.
  • 02-10-2011 4:38 PM In reply to
    Thanks, Olly. I've only three servicable clips and they are on the ends. Makes the whole works mushy, especially lower right 'GO'. Looking for a replacement I think.
    Brian
  • 02-10-2011 4:46 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Grind off the remains of the clips.
    Glue on screws with cylindrical heads of apprx 2.5mm height to the backside
    of the panel (where the clips sat), standing on their heads.
    Fit the board with nuts to the screws.
  • 02-10-2011 5:36 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Ah yes, a trick even B&O have used, how clever! Will a standard two-part epoxy stick ok to the plastic?
    Olly.
  • 02-11-2011 12:29 AM In reply to
    Now why didn't I think of that? Brilliant, and thanks!
    Brian
