1st March February 2012
Latest post 02-06-2011 6:12 PM by tournedos. 7 replies.
02-06-2011 4:49 PM
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Silly question maybe but I have tried to connect RX2 and 3300 recordplayers on my Beomaster 7000, both on AUX and Phono but no sound at all. Is that because the Beomaster 7000 has no pre-amp?
Thanks, Leslie
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Søren Hammer
- Joined on 01-07-2008
- Esbjerg/Denmark
- Posts 554
I am almost sure that the Beomaster 7000 didn't have a preamp on the phono input. Buy a standard phono RIAA pramplifier and you'll be fine
Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
Leslie
- Netherlands
- Posts 2,201
Thanks guys, I reckon the Beomaster 6500 has the same "issue"?
Mut have a 5500 somewhere, that will work does it?
Søren Hammer
- Esbjerg/Denmark
- Posts 554
The 6500 is also without preamp i believe, and the 5500 has it, and it will worke fine with the Beograms who doesn't.
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Have you not got a Beocenter you can try it on? Can't think of any without a built in RIAA.
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Leslie
- Netherlands
- Posts 2,201
I have Craig but not connected, hide it somewhere in my closet (shame on me )
Will try it later, thanks!
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Craig:Have you not got a Beocenter you can try it on? Can't think of any without a built in RIAA.
9300, all of the upright Beocenters, and Beocenter 2
But
anyway, both of these record decks need a preamp, simple as that. But
even without, you should hear at least something when you crank up the
volume high enough.
Page 1 of 1 (8 items)
