Latest post 02-05-2011 12:01 PM by Vienna. 4 replies.
Page 1 of 1 (5 items)
  • 02-05-2011 6:15 AM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Masterlink Junction boxes
    Hello All Do you good folk use masterlink junction boxes. I was recomended to use 3amp terminal block What do you all do? Solder them? Masterlink Junction Boxes? Terminal Block? Also what is this i hear that if you have broken into a ML cable that you should connect the White and Blue (ML-Sence) and the Pink (= supply voltage) together?? Would this explain how 9 ML cables can be connected using cat6/7 with only 4 twised pairs? Please help me!!! Thanks
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 02-05-2011 6:34 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Masterlink Junction boxes
    Yes, that's the explanation ...  Smile
    Pin 3 Blue/White and Pin 12 Pink always have to be connected, which happens automatically if you are
    using a Junction Box or a ML Distributon Box.
    I personally prefer the use of ML Distributon Boxes instead of J-Boxes or soldering
    - especially in larger ML setups.
    6 ML Cables with Plugs can be connected and easily disconnected - making fault finding a lot easier.
  • 02-05-2011 6:43 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Hi there Thanks for that so just to clarify on your reply the pin3 and pin 12 are conected together. I think i might invest in a ML dist box but i will still need to use junction boxes to make up the ends after the cable has run through the joists and through walls. So just to clarify the blue/white is also connected to the pink?
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 02-05-2011 6:58 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Well indeed after buzzing out with a multimeter they are indeed connected in a junction box. I think i will pop to the shop and buy some cat7 and put that in place for a 1/4 of the price of ML
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 02-05-2011 12:01 PM In reply to
    • Vienna
    • Posts 712
    ... cheaper cable per m does not necessarily mean lower total costs Smile
    Generally speaking:
    - It's easier to make a "nice looking" installation using ML - especially if you crimp the ML plugs directly
      to the ML-cables without J-boxes (but you will need assistance of your B&O dealer/installer).
    - If properly installed, a Cat 7 installation will offer considerable advantages in the (near) future.
