Latest post 01-26-2011 10:53 AM by thewoo. 2 replies.
Page 1 of 1 (3 items)
  • 01-26-2011 8:47 AM
    • thewoo
    • Not Ranked
    • Joined on 01-26-2011
    • Posts 5
    FM aerial for Beocenter 9000
    I just bought my first Bang & Olufsen - a Beocenter 9000 (amazing!). I'm looking for an affordable FM aerial, but the the socket on the beocenter seems rather small and I'm not sure what plug would fit. I don't want to buy one and find out it doesn't fit, and I can't afford a vintage part. Could anyone give me any pointers? I saw this on ebay but I'm not sure the plug would fit:
    http://cgi.ebay.co.uk/FM-AERIAL-KIT-RADIO-RECEIVERS-BALUN-UNIVERSAL-/310283558296?pt=LH_DefaultDomain_3&hash=item483e575d98#ht_2062wt_825
    Thanks,
    Mat
    Filed under:
  • 01-26-2011 9:00 AM In reply to
    Re: FM aerial for Beocenter 9000
    Hi Mat,
    congratulations on your purchase and welcome Smile
    Seems to me the kit in your link should work just fine. You'll need to use the female-female adapter which is included (the socket in your Beocenter is male).
    -mika
  • 01-26-2011 10:53 AM In reply to
    • thewoo
    • Not Ranked
    • Posts 5
    Brilliant, got it ordered. Thanks very much.
