1st March February 2012
Latest post 01-17-2011 2:05 PM by Evan. 10 replies.
01-12-2011 7:03 AM
ajames
- Joined on 05-04-2007
- Posts 275
Does anyone know if an automatic input selector (for the aux socket on beosounds) is yet on the market by anyone?
Must be a great demand for something that could be hidden away and allows you to connect ipod, turntable etc. to a Beosound with only 1 aux socket. I beleive this has been discussed before and someone was going to look into producing one if there was enough interest.
Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
ajames
- Posts 275
Re: Automatic Input Selector
Hi, thanks for the reply, yes, I looked at the Video ones and the problem is that they don't switch automatically for audio as they need the 5v (I think) signal on the scart lead in order to switch over. What's needed is something that senses an audio signal and then switches to it - bit like the active speakers switch on when they get an audio signal through the jack plug.
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
If the demand actually was great (meaning also others than just us B&O nerds needed one), you could already get one made in China for little money. Other folks just buy a new plastic AV receiver if they run out of inputs.
I would design such a switcher if I needed one, but I don't think it would ever be viable as a business, or even to compensate for the lost free time. Producing 20 or so PCBs for a construction kit could work, but then you'd still need to hack up an enclosure and other mechanics yourself.
And since we are with B&O, the moment you had a simple audio switcher, somebody would like it to do something intelligent with the Datalink from a single Beomaster input to the connected multiple peripherals. So it won't end up being so simple after all.
Personally I would need a switching matrix for passive speakers...
ajames
- Posts 275
True, I doubt there is enough demand outside of these circles and a manual switchbox does the job but looks unsightly and messy. Maybe a BM5500 and Beogram CD would be better than my BS3000 with it's broken CD player and 1 input! It would also mean I wouldn't need a seperate pre-amp for the turntable!
ajames
- Posts 275
Not a bad idea, especially if you hooked it upto a Lintronic box - that would give you automatic switching and control of the non b&o devices. Do you know who makes the infrared ones?
Andrew
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
If you have to use your Beo4/5, then yes, a Lintronic box would certainly help.
As far as the A/V switches, there are a bunch. Just do a search on google shopping. The most popular one seemed to be the RF-Link 4in/1out unit with IR control. I believe the model is AVS-41.
Page 1 of 1 (11 items)
