        1st March February 2012
	    Latest post 01-20-2011 2:39 PM by  yachadm. 22 replies.
								        12-29-2010 4:39 PM
									        tournedos
								                - Joined on 12-08-2007
								                - Finland
								                - Posts 5,808
										    Re: Beocenter 8000 CD stopped working
										    Hi there.
I had a similar problem in mine - afterwards, I think it's possible that I didn't place the CD
properly when loading it and it wasn't able to rotate, overloading the
mechanism.
In any case you do have some real electronic repair
work to be done. The bad part is that a dealer won't be able to help
you, most probably they will just say that the CD mech is unavailable as
 a spare part and therefore it can't be repaired. You'll either need to
look into it yourself if you're capable, or find some 3rd party to take
care of it.
The "wobbling" part in your description sounds like
you might have some mechanical problems with the spindle or loading
mechanism, though... does / did the door close properly?
									        Stonk
								                - Joined on 04-16-2007
								                - Marlow, Bucks, UK
								                - Posts 1,688
If you think nobody cares, try missing a couple of payments.
									        tournedos
								                - Finland
								                - Posts 5,808
										    Agreed - take a look at the other thread I linked to. If for example
one of the transistors has shorted, it'll spin the motor, burn the
resistor and the servo circuit can't control
 the motor speed any longer.
But this is all speculation, so it will need to be looked at. As said in the other thread, DON'T touch the adjustments!
									        Die_Bogener
								                - Bogen, Germany
								                - Posts 1,010
										    Replace transistor 6124 and 6125 and the two burnt resistors direct next to them. That's all.
And replace 2103 by a 47uF 16V axial type. Either original Philips or the newer type "BC" components. It must be a blue cap, nothing else. This cap is picky.
									        tournedos
								                - Finland
								                - Posts 5,808
										    That's a detailed enough picture
Near the two wires to
the spindle motor, you see the two driver transistors (6124 and 6125).
Above and below them are the two 10 ohm safety resistors. They obviously
 have been hot, the lower one seems to have even bubbled a bit, perhaps
enough to create smoke. Measure them, and you should also test the two
transistors. Might be easiest to just replace all four components.
If the transistors need to be replaced, make sure to get the
higher gain (-25) versions instead of basic BC328 and BC338. There must be reason why those were used originally.
									        Agent00soul
								                - Joined on 11-10-2010
								                - Solna, Sweden
								                - Posts 61
										    Those 10 ohm resistors definitely look fried. Time for a trip to Elfa...
									        tournedos
								                - Finland
								                - Posts 5,808
										    Any regular 10 ohm resistors will do, metal film 0.3W for example. Don't up the power rating much though, or they won't act as fuses as they were designed to anymore.
There's plenty of discussion on that C2103 on the forum, most recently here. The easiest way out is to get a ready assembled kit of all caps worth replacing on this board from member Dillen, then you'll get types that are known to work.
If you get stuck with the transistors, I can drop a pair in the mail for you. I always buy a larger batch of cheap components like this even if I need only one at that time.
									        Agent00soul
								                - Solna, Sweden
								                - Posts 61
										    I replace basically any small signal transistor with BC550C/BC560C. As long as it looks the same, it will usually work. There are exeptions of course, but they are few. You need to make sure it's a NPN or PNP transistor of course. FETs are another thing.
For resistors I always use 0,6 W metal film. That way I only need to stock one type and can buy 100 at a time, which makes the cost acceptable.
									        Die_Bogener
								                - Bogen, Germany
								                - Posts 1,010
										    The BC550 will have a very hard time, to replace with his 100mA maximum current a 800mA type BC328/338...
And it has a reason, why B&O used this type of coal resistors. 0.6W metallfilm with its high capacity for overload will cause also a hard time for the stressed components... the resistors are fuses and for limiting the current during overload. If you use a 10W type, it will never blow, just the motor or the power supply will burn ...
									        Agent00soul
								                - Solna, Sweden
								                - Posts 61
										    OK, I suppose this is one of the exceptions then. Elfa has the BC368, which might work (NPN, Ic-max 1 A). A suitable PNP transistor could be the BC640, which Elfa also stocks.
									        Die_Bogener
								                - Bogen, Germany
								                - Posts 1,010
										    The cheapest coal resistor is good enough... 5% 0,25W.
Use the Fairchild BC328...
Vishay BC Components was PHILIPS some years ago, ähm, they bought it ... ;)
									        Agent00soul
								                - Solna, Sweden
								                - Posts 61
										      Die_Bogener:
What type are the original resistors, by the way? They have five bands: brown-black-black-gold-purple.
I have never seen a resistor with a purple band for tolerance. Does in mean 0.7%? It can hardly be 7%, as it has four bands for resistance value, whereas 5% carbon film resistors have only three bands. I would guess they are some kind if metal film resistors, as they look very similar to 1% metal film resistors and have the same number of bands.
									        Agent00soul
								                - Solna, Sweden
								                - Posts 61
										      Marcus:If the fifth band is purple that means that the tolerance for the resistor is +-0.1%.
WOW, you're right. I wonder why they used them and if the low tolerance is neccessary.
Even more strange are the three resistors below the burnt ones that seem to have TWO gold bands. That's not covered by my resistor colour code guide. Are they really gold?
Well, I suppose if the purple bands really mean something else, the burnt ones would be 10 ohms 5% and the three below them would be 1 ohm 5%.
									        yachadm
								                - Joined on 06-24-2007
								                - Jerusalem, Israel
								                - Posts 687
										    These are Vishay BC NFR25 Fusible, non-flammable resistors.
Do not replace them with any other type.
In the Philips CDM2 Service Manual, they are listed as safety components, not to be substituted with anything else.
I have stock of these on hand.
Metal Film are not wise replacements here anyway, even if the originals were not the NFR type.
In power circuits, Carbon-type resistors still handle heat much better than metal-film. As technology develops, this may change, but right now, this is the case.
Metal-film are excellent for audio circuits, though.
See this article:
http://www.condoraudio.com/wp-content/uploads/Reviews/How-to-Choose-Replacement-Capacitors-and-Resistors.pdf
Of course, the high-current here is obvious - the fusible resistors burned. The BC560 (PNP) series would not last long under normal conditions. They are excellent transistors in signal applications, though - very quiet!
Menahem
									    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
        Page 1 of 1 (23 items)
