I bought a powerlink cable on ebay and its an mk2 can i use this for conecting my Beosound 9000 to my Beolab 8000's as i believe mk2 are generaly for units with dispays and mine do not but can you still use them anyway? Thanks
Yes! - probably larger diameter cable than the Mk 3
Tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
Well i got my powerlink cable came in B&o box part number says 6270698 it works fine if just plug it in to my beolab 8000's but i can't seem to get it to plugged in to my Beosound 9000 i am wondering if i am going to have to take the BS9000 off of the verticle stand to get this plugged in or is there something wrong here? is there some trouble with these plugging cables in to them? Thanks Roger
?? maybe you tried to plug the 8 pin Powerlink into the 7 pin Aux input by mistake ??
Thanks but i thought about that i saw the diagram insde the Beound it says Master link,powerlink left, powerlink right,then Aux i plugged in right next to the Mastererlink
Try it the other way round, that might work , if the plug will not fit the other unit then plug/pin problem ie pin alignment
good luck!
tony
i can plug in both ends on my Beolab 8000's but i can't get either end to plug into the Beosound 9000
