Latest post 01-09-2011 10:11 AM by tournedos. 9 replies.
Page 1 of 1 (10 items)
  • 01-08-2011 4:10 AM
    Pickup cartridge MMC
    Hi guys,
    A friend of my fathers have an old B&O system that he needs an MMC 20S cartridge for...
    Where can I find one for him, and is this the only one, or is it to similar specs to that of other MMC cartridges?
    Thanks in advance,
    Andreas
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 01-08-2011 5:47 AM In reply to
    Re: Pickup cartridge MMC
    Hello,
    You can use all the MMC20-series of carts, the S was the cheapest then, but In my opinion it sounds better than the E, EN and CL if it is an old one. It kind of gets the B&O sound right with a warm bass and overall well balanced soundstage.
    Try to look after some non-working turntables on your local listing site, They must be equipped with a MMC20S, MMC20E, MMC20EN or MMC20CL.
    -Søren
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 01-08-2011 8:47 PM In reply to
    Soundsmith
    http://www.sound-smith.com/cartridges/boall.html#classic
    Or Axel Germany may have as well
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 01-09-2011 2:45 AM In reply to
    Andreas, here you can find Axel.
  • 01-09-2011 5:22 AM In reply to
    Thanks for the links!!!
    I'll try Axel, he has some good deals on refurbished cartridges.
    -Andreas
  • 01-09-2011 7:50 AM In reply to
    bayerische:
    I tried to look earlier, but he doesn't seem to have any of these models on the webshop (doesn't mean he couldn't still sell one, though).
    You could also buy one with a broken needle from fleaBay and send it to Axel for repair. The "working" (and even NOS) cartridges will need it sooner or later anyway.
    Any cartridge from MMC3000-6000 series will also work.
    I think I have a working MMC20S sitting somewhere - I don't want to sell it as I'll need it myself some day, but I could borrow it while you look for another.
    -mika
  • 01-09-2011 9:48 AM In reply to
    tournedos:
    bayerische:
    Thanks Mika, but since it's for one of my fathers friends, I can't take you up on your excellent offer!
    But this one, isn't it a repaired cartridge?
    http://www.schallplattennadeln.de/B-O-MMC-Reparatur-Repair/REPARATUR-MMC-20/MMC-20-S-E-Reparatur-mit-neuer-elliptischer-Diamant-Nadel.html
    -Andreas
  • 01-09-2011 9:56 AM In reply to
    Unfortunately not, it's just the repair service for a cartridge you send in.
    -mika
  • 01-09-2011 9:58 AM In reply to
    tournedos:
    OK, but that should work, since he has the old one.
    -Andreas
  • 01-09-2011 10:11 AM In reply to
    Oh yes, then it is definitely best to get that one fixed! I assumed the cart was missing completely.
    The link you quoted is for an elliptic stylus, so it will actually be a slight upgrade - the end result will be just like an MMC20E.
    -mika
