Latest post 12-21-2010 5:11 PM by stefan. 1 replies.
Page 1 of 1 (2 items)
  • 12-21-2010 4:25 PM
    • anbi
    • Not Ranked
    • Joined on 12-21-2010
    • Posts 1
    Beomaster 4500 and Argon turntable
    I have just bought a new turntable Argon TT-1 to play my old records.There is no sound in my amflifier Beomaster4500. I have correct cabels, I hope. Do I nead some devise ore cabel in between my Beomaster and my turntable?? Please help me. Merry christmas.
    anbi
  • 12-21-2010 5:11 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Beomaster 4500 and Argon turntable
    I assume you have connected your Argon turntable to PHONO input via an rca - DIN adapter. This should work, if your Argon has an inbuilt RIAA preamp. If this is not the case you can connect an external preamp.
    And be aware that DIN plugs in all Beomaster have four connections - two inputs (left, right) two outputs (left, right). Maybe you have connected the Argon to the outputs....(?)
    BTW we are in the scandinavian forum, so this is the "wrong" language - sorry
    Stefan
