Latest post 12-29-2010 10:33 AM by beoguy. 4 replies.
Page 1 of 1 (5 items)
  • 12-29-2010 8:50 AM
    Beovision 6-26 blinking standby light...
    Ok...so as I am trying to fiqure out how to hook up my Blu-ray player to this, I have been plugging cables in and out, here and there.  Now whaen the tv is off, the red standby light blinks!
    What does this mean?
    Guy
  • 12-29-2010 9:22 AM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Beovision 6-26 blinking standby light...
    I think you need to put the PIN to the TV!
    Best regards
    Spiros
  • 12-29-2010 9:38 AM In reply to
    I have the same problem on BV7, has nothing to do with the pincode, so I'm hoping for an other answer...
  • 12-29-2010 9:52 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Press "TV" or "DTV/SAT" and see if the screen for entering the PIN is displayed,
    if yes, key in PIN
    if not, switch TV to stby and UNPLUG power for approx 5 min,
    before reconnecting to the mains again.
  • 12-29-2010 10:33 AM In reply to
    Great!  Unplugging it for a while and plugging it in did the trick!  Thanks!
    Guy
