Hi folks,
I managed to get an MX7000 for free but without RC though.
I'm not sure which one is compatible with this model and obviously if not necessary I wouldn't buy the most expensive one.
Any help would be greatly appreciated.
Happy Christmas!!!
Well you can buy a cheap plastic remote on eBay which will work - but I wouldn't! A Beolink 1000 would be a cheap but good remote and the Beo4 would be the standard remote. Both would work well and be easy to use.
Many thanks for that I've already ordered it
Cheers
