1st March February 2012
Latest post 07-12-2007 1:18 PM by 355f. 18 replies.
07-10-2007 12:02 PM
massimo
- Joined on 04-19-2007
- Posts 28
realistic life expectancy of a plasma panel ???
Guys, I'd like to buy a BeoVision 9... just love it and I'm ready to lay out the cash... but my concern is: - I'm hearing a lot of people concerned about Plasma panel lifetime... they all say that the quality of the image goes down pretty fast, and you should not expect to keep such panels for 15 years... after 2-3 years you can already notice a change in the quality of image... Is that true??? ...what is a realistic expectation for a BV 9 lifetime??? If I have to spend that kind of money I of course don't want to replace the TV after 6 or 7 years. One more thing about the BV9... would burn in be an issue here??? All advises will be very appreciated... thanks and regards from Italy!
zencliff
- Joined on 04-18-2007
- Silver Spring Maryland USA
- Posts 2
Re: realistic life expectancy of a plasma panel ???
Panasonic says 50000 hours. Or at 5 hours TV watching a day (the average American's TV diet)- 27.39 years
joynsyde
- Joined on 07-09-2007
- Midwest, U.S.A.
- Posts 130
Greetings to Italy!
I'm no video expert, but I have done some research, and I do know that the first generation of plasma screen TVs (over a decade ago!) had problems with burn-in and low life-expectancy. They got a bad reputation from that, due to CRT manufacturers feeling threatened and releasing negative marketing about plamas. However, the newer screens have improved dramatically.
Check out this very good article: http://www.pioneerelectronics.com/pio/pe/images/portal/cit_3424/273087528Pioneer%20DTV%20White%20Paper%20-%20FINAL.pdf Notice especially the part starting on page 5, where they talk about life-expectancy. They played a movie continuously on a rear-projection TV, an LCD, and a plasma for 4 weeks. At the end, the plasma had only decreased in brightness 5%, while the other two had decreased in brightness 11% and 23%. Of course, this is an abusive way to treat a screen; it would be comparable to playing music through your loudspeakers with the volume turned all the way up for days in a row. Components do better if you let them cool down between usages. And of course, this article is about the mass market of plasma screens--the cheap TVs from other brand names. However, with B&O, you know that they are not content with the status-quo. They use highest-quality components in their products, and that would include the phosphor bulbs in their plasma screens. Their attention to detail, the fact that they hand-make almost everything in-house, and their excellent track record for making long-lasting products, should assure you that you are getting a long-lasting TV of the highest quality. I'd say, "Go for it!" Regards from the USA! Aj.
...my two cents
~AJ
355f
- Posts 655
Of course B&O dont make the screen, they buy it from the panasonic plant in China. b&o do use the commercial varient of the panel which makes it more long lived. You are not buying a hand made product from B&O in this regard! handmade by chinese on low salaries yes!! the earlier plasmas tended to suffer from pixel defeat after a while so you were left with unilluminated pixels on the screen and the gas in between the two sheets of glass would dissipate over time( this is why its called plasma) Thesze issues are resolved. The previous poster makes refernce to a Pioneer link explaning the virtues of Plasma and to some extent what is said is true- BUT pinoeer is in a mess having gone down the plasma only route when the mass market is now in LCD! Plasma life is indicated by the term 'half life' this is the point at which the panel is half as bright as it was when it was new.It is not a question of quality of image dropping. No one talks of LCD life of course, assuming it goes on forever. In fact they only last as long as the backlight does and the higher the brightness - expectancy is reduced. Once the back light has gone the panel is US. I have an original panasonic commercial panel( which is the same as B&O use) the panel is more robustly constructed than a normal domestic panel. The is panel has been used every day for 7 years and I have noticed only a slight loss of brightness compared to new. I also have a new BV4 50" Despite having static images displayed quite a bit there is no 'plasma burn in' all in all I would not be to worried about the life of the panel at all I think you will find the electronics will be outof date before the panel!. Also as the beosystem 3 is hung on the back of the BV9i would think it would be easy to upgrade the panel inside ( in the same way you can the BV4. This was a lot more difficult on the BV5 which was more integrated I went for the BV4 as with BS3 its the best picture out there and LCD is simply no match at all.
archie
- Joined on 04-16-2007
- Paris
- Posts 497
i have a pioneer plasma since 3 years, and all is OK no burning. the problem with a 21000 euros plasma is than the technologie grow very fast, too fast. For the 4000 euros of my old 43 inch HD ready plasma i can have now a full HD 55 inch. In 5 or 6 years you will by buy a 120 inch oled TV for 5000 euros, and your BV9 seems very litle.
355f
- Posts 655
archie: i have a pioneer plasma since 3 years, and all is OK no burning. the problem with a 21000 euros plasma is than the technologie grow very fast, too fast. For the 4000 euros of my old 43 inch HD ready plasma i can have now a full HD 55 inch. In 5 or 6 years you will by buy a 120 inch oled TV for 5000 euros, and your BV9 seems very litle. This is a totally different point of course. First of all I can tell you that oled, laser tv, sed tv are still so far from reality and indeed the problem now is that the prices of plasma and lcd has dropped so much the manufacturers are wondering if they will ever get an invstement back that they make in new technology for display manufacture. How can they introduce another flatscreen technolgy that is so much more expensive than that presently offered?? fact is no one will buy it! so for the next say 4 years I dont think this is an issue. There are still reliability issues to be overcome with oled for example!!!! whlst the advances in panel design have been large over the past seven years, each new variant is not such a large leap forward now. So the point is one wants the best picture one can get now and the BV9 really is good that I dont think one is going to be saying in 5 years that one regretted the purchase. The differences in technolgy are smaller and smaller with each advancement. One can use the argument that one could buy another make of plasma but as many have discovered, it doesnt offer true compatability with the BS3 there seems to be scalling issues, you cant adjust contrast features on it, sone have to use a non B&O remote and do you really want say a pioneer panle with all your B&O equipment
chrisped
- Joined on 04-17-2007
- Oslo
- Posts 125
Another little point worth mentioning is that in a recent survey covering Japan, China, Germany, France, and England - 4 out 5 respondents prefered the plasma picture over the LCD picture in a side-by-side comparision. http://www.engadgethd.com/2007/07/05/recent-survey-suggests-plasmas-preferred-over-lcds/
massimo
- Posts 28
All great advises guys... you have made this a little bit clearer for me... thanks a lot!!! Massimo
joynsyde
- Midwest, U.S.A.
- Posts 130
355f:Of course B&O dont make the screen, they buy it from the panasonic plant in China. b&o do use the commercial varient of the panel which makes it more long lived. You are not buying a hand made product from B&O in this regard! handmade by chinese on low salaries yes!!
Just curious where you get your information from. I was told by my B&O dealer that they get the glass for their plasma screens from Japan. Japan has invested in the infrastructure to have large glass factories, and Struer wouldn't be able to support the personnel, space, and supplies needed for a large glass factory (not to mention the pollution). But B&O buys the best glass panels available, then brings them home, applies their special coatings, arranges the other components, and so on. Of course Bang & Olufsen doesn't make every single component from scratch! That would be stupid. NO company does that, for that matter. But nobody would say that a restaurant doesn't make their own food just because they don't grow their own vegetables and butcher their own animals. Restaurants buy ingredients from suppliers, and "assemble" everything at the restaurant. The quality of the food suppliers is part of the recipe, but the real magic happens with a good chef. Same with B&O. They buy highest-quality components, then engineer and assemble everything at home. I'm sure they don't make their own speaker cones, copper wires, screws, etc. If they did, everything would be 10 times more expensive than it is! But the ingenious way they use those components is just magic!
...my two cents
~AJ
355f
- Posts 655
joynsyde: 355f: Of course B&O dont make the screen, they buy it from the panasonic plant in China. b&o do use the commercial varient of the panel which makes it more long lived. You are not buying a hand made product from B&O in this regard! handmade by chinese on low salaries yes!!
I get my information as I run an electronics company based in China that manufactures audio and some video products for many of the brands ( not B&O!!) I appreciate that a company cant buy all the 'ingredients' as you put it but in this instance they are buying vitually a READY MADE MEAL!! I can assure you of that! I like B&O and whilst I could have any brand I choose it because it looks good and the integration is good. DONT make the mistake of thinking that because one pays a HIGH price one is buying the very best components! in many instances the items used are of a rather POOR quality and this is FACT! What B&O are good at is taking the 'ready made meal' and spending some time on the engineering side seeing how best they can improve what is already made ( in the case of plasma- not some audio) and because the japanese brands ( who all have operations in China) dont spend money on good tuners B&O work the magic to make it better, look better and integrate it. THAT is what you pay for it is simply NOT about quality at all! The B&O plasmas are the PANASONIC D9 and D10 variants, I have both and if you take the backs off there is NO difference! ------- oh yes there is!!!! B&O REMOVE the tuner but charge 6 times the price for the panel. However your B&O dealers story is a nice one!!
joeyboygolf
- Ely, Cambridgeshire, UK
- Posts 3,252
Us good people of the so called 1st or civilised world need to wake up to the fact that we cannot afford to actually make anything from raw materials any more. The dirty work is all done in those countries where you are still allowed to pollute the environment and kill off the workforce while paying them peanuts! Our environment police together with our inflated wage rates have simply priced us out of our own markets. Comodities like glass, steel, bulk chemicals etc are all now made in places like China. In the last decade or so we have also taught them to actually combine these "raw" materials into a finished product in their sweatshops. Western and Japanese conglomerates place them in a box designed to look familiar to western eyes and sell them as their own. B&O buying glass from Japan!!!! I don't suppose there is anywhere in Japan where they are still allowed to make glass or where they could afford to make it.
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Wow, strong stuff, Graham! Andy T.
355f
- Posts 655
joeyboygolf: Us good people of the so called 1st or civilised world need to wake up to the fact that we cannot afford to actually make anything from raw materials any more. The dirty work is all done in those countries where you are still allowed to pollute the environment and kill off the workforce while paying them peanuts! Our environment police together with our inflated wage rates have simply priced us out of our own markets. Comodities like glass, steel, bulk chemicals etc are all now made in places like China. In the last decade or so we have also taught them to actually combine these "raw" materials into a finished product in their sweatshops. Western and Japanese conglomerates place them in a box designed to look familiar to western eyes and sell them as their own. B&O buying glass from Japan!!!! I don't suppose there is anywhere in Japan where they are still allowed to make glass or where they could afford to make it.
Amen, The chinese care only about one thing MONEY, quality and decency in manufacturing China are not words mentioned. Whilst the west and in particular the UK set up 'the Carbon trust' and other worthless tax raising bodies China goes on with No or very little controls, no red tape, building 4 new coal powered stations every week to support the growth that our political system wont allow in our own countries. Of course American industry is at last aware of the devasting effects on their jobs and economy and now want trade limitations. Rather than have all these bodies to Tax us on everything based on a 'carbon footprint' why not simply issue a levy on any items imported from China that are not made in an environmental way. Hence allowing a level playing field.
joynsyde
- Midwest, U.S.A.
- Posts 130
Yes, strong stuff, and I feel like there's a lot of emotion going on in this thread. Yet, all I've seen so far is speculation. 355f said the back of his BeoVision looks exactly the same as the back of his Panasonic, except there's no tuner. (That's not very exact.) And he implies that because a lot of AV companies buy components from his electronics factories in China , Bang & Olufsen surely must do the same from some other company. (Not that that's necessarily an unfair assumption, but it's still an assumption.) And Graham doesn't "suppose" Japan has glass factories. Do we have any documentation? Official statements from the company itself? Sorry, the scholar in me is coming out!
Not that it matters, really. The specific topic we are dealing with is BeoVision 9, and we all agree that it is a wonderful television, no matter how many countries it goes through before it gets to your home. We can gripe all we want, but if we really don't agree with globalization and the use of sweat shops, and so on (and I surely don't), we should take meaningful actions to promote meaningful solutions. Meanwhile, we should get solid facts before accusing a company of doing something we disagree with. Best, Aj
...my two cents
~AJ
355f
- Posts 655
joynsyde: Yes, strong stuff, and I feel like there's a lot of emotion going on in this thread.
I think we are getting a little confused here! Our company makes the finished product in China and it is then branded with the appropriate name and distributed worldwide. If you want facts. the FACT is the panel is made by panasonic and its a D9 or D10 panel!! I will post pictures of the two side by side- they are IDENTICAL apart from the removal of the tuner- This is FACT. and will show the unit covered with made in china on it! The service manual for the BV4 range asks that for certain procedures you should use the 'no name remote' and it clearly shows a panasonic remote!! even the sensor that panasonic use is covered over by the alu frame!! anyone that has a BV4 take off the frame and you will see it!! as further proof if you need it I would be happy to mail you ofline with the name opf the company that makes the BV8 IN CHINA tthere are other products that are made mainly in china as well.
joeyboygolf
- Posts 3,252
At one time in my life I worked for a number of years for the Philips group. They were one of the biggest manufacturers of CRT's in the world with glass factories in a number of countries including the UK. Glass production moved to China and India and was shipped back to the UK for assembly. Now they make the whole sets in China and ship the completed sets back to the UK for sale. The only thing that is British manufactured is the price tag! I don't find anything wrong with this, it is pure common sense economics. What I don't understand is the reluctance of many of our members to acknowledge that it goes on and are surprised to find B&O goods with "made in China" stickers on them. I am sure that most manufacturers now manufacture in China, they can't afford to manufacture anywhere else.
355f
- Posts 655
Firstly our company makes the finished product for the brands- not the components. I will endevour to post pictures of the back of the panasonic G9 and the latest version of BV4. If you remove the alu trim from the front of the plasma it reveals the panasonic frame -and the B&O frame even covers the IR eye that is used on the panasonic screen. In the service manual for BV4 certain procedures require the use of 'the no name remote' as B&O call it- but clearly show the panasonic remote! The BV8 is made entirely in China and I can furnish you with the factory name off line if you so desire. Im trying to be as exact as I can!
frog
- Posts 191
355f. while you are totally correct in your statements about the D9 panel being in the BV4, I'm puzzled why you say that they are the same without the tuner - the D9 doesn't have a tuner at all - it is just a monitor. Another point to make to confirm 355fs point; why does the BV4 have speaker outputs on it - surely if B&O manufactured it, then they wouldn't need it! Also B&O don't coat the Panasonic screen, they put a separate anti-reflective screen in front of the D9 panel - it can be seen in the BV4 technical guide. The evidence is overwhelming....
355f
- Posts 655
frog: 355f. while you are totally correct in your statements about the D9 panel being in the BV4, I'm puzzled why you say that they are the same without the tuner - the D9 doesn't have a tuner at all - it is just a monitor. Another point to make to confirm 355fs point; why does the BV4 have speaker outputs on it - surely if B&O manufactured it, then they wouldn't need it! Also B&O don't coat the Panasonic screen, they put a separate anti-reflective screen in front of the D9 panel - it can be seen in the BV4 technical guide. The evidence is overwhelming....
Your right of course!! what I meant to say was that the circuitry has been slighly modified to allow full control with BS3 not removal of the tuner which as you correctly state is not in the commercial plasma only domestic versions( i have a panasonic with tuner included) But in fact if you look at the domestic versions they look the same but with inclusive tuner. As you quite rightly state the speaker outputs are pure panasonic-- no need or use for them for B&O
Page 1 of 1 (19 items)
