Latest post 07-12-2007 2:52 PM by Frank Rizzo. 3 replies.
Page 1 of 1 (4 items)
  • 07-10-2007 11:52 PM
    Back of an IR eye.
    Thanks to everyone for all the help...
    The Beolink Active I got had 2 IR eyes.... they came with nothing else...no back, nothing... what is there supposed to be there to mount them>>??
    THanks,K
  • 07-12-2007 12:47 PM In reply to
    • frog
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Posts 191
    Re: Back of an IR eye.
    There is a small disk that screws onto the back of the eye which has two holes for screws to mount on the wall. Don't know if these can be had as a spare part from B&O - but worth a try. If not, you could get the 'in wall' fitting which may not need this disk.
  • 07-12-2007 12:53 PM In reply to
    I can confirm that you do not need the backplate if using the "in wall" fitting
    Regards Keith....
  • 07-12-2007 2:52 PM In reply to
    Thanks guys.... I just ordered 2 of the "in wall" kits made for brick enclosures...as in South America...all construction is brick/concrete/mortar.....
     Thanks again..
     K
