Latest post 07-11-2007 4:57 PM by BenSA. 4 replies.
Page 1 of 1 (5 items)
  • 07-10-2007 6:08 AM
    • BenSA
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Beovox 5700 Tweeter repair?
    Is it possible to repair a tweeter from a Beovox 5700. The whole speaker box was dropped and tweeter stopped working. I tested it on the other speaker where the tweeter works and it doesn't work there either! It makes a slight hissing noise, have to put your ear right up against the tweeter to hear it. Repair possible on my own? I would think a replacement would be rather difficult to find!
    Durban South Africa
  • 07-11-2007 3:39 PM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    Re: Beovox 5700 Tweeter repair?
    Sad
    Durban South Africa
  • 07-11-2007 4:19 PM In reply to
    The problem you will have is getting it done economically. Recone Lab do repair tweeters - they repaired one of the ones on a pair of MS150s for me.
  • 07-11-2007 4:33 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Francoisvl,
    PM me any details you have on the tweeter or a photo. I may have a good used one in stock but need to know the exact type to tell for sure.
  • 07-11-2007 4:57 PM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    Thanks Martin! I will take a photo when I can and will pm you. I'll keep my fingers crossed on the meantime that you do!!
    Durban South Africa
