Latest post 11-21-2010 11:05 PM by Russ. 5 replies.
Page 1 of 1 (6 items)
  • 11-12-2010 5:48 PM
    need help: connect BL5, BS3 and digital
    hi,
    I need some help from someone that has the same configuration:
    Beosystem 3 : front BL5, surround BL1, center BL4000
    Before, my BL5 were connected via DIGOUT from Beocenter 2. Now, I wonder how should I connect them via DIGITAl. There is no DIG OUT on the BS3. I would like to listen music on DIGITAL and watch movies on 5.1.
    Also, what is the benefit of connecting Beocenter 2 to BS3 via Masterlink?
    I cannot figure out also how to switch betwwen : Dolby Digital 5.1/6.1 EX, Dolby 7.1 EX, Dolby Pro-Logic
    ll/llx, DTS 5.1. DTS ES 6.1, DTS Neo:6 ?????????
    Any help will be highly appreciated,
    many thanks
    all sold!
  • 11-12-2010 11:22 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: need help: connect BL5, BS3 and digital
    For the first part of your question....  Connect the digital out from the BeoCenter 2 Socket box as before, but the PowerLink connection will be from the BeoSystem 3.  Make certain that the PL cables are the ones supplied with the BL-5's or fully wired.  On every other source the BL-5's will play from the PL cables; but from CD they will look for and lock on to the Digital connection.  Also, software updates all around.
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 11-13-2010 6:47 PM In reply to
    thanks Russ....
    do I have to connect the output digital chain on the BL5 to AV ??? input on the Beosystem?
    thanks
    all sold!
  • 11-19-2010 11:08 AM In reply to
    • Russ
    • Posts 641
    Yes, you do.  Daisy-chain from the socket box through the 2 BL-5's and then on to the BS-3 AV input.
    McLean, VA USA
  • 11-21-2010 6:25 PM In reply to
    • pavur
    • Not Ranked
    • Joined on 10-20-2010
    • Posts 4
    in the Customer Service Menu you can switch between Dolby Pro-Logic IIx Music/Dolby Pro-Logic IIx Movie/DTS Neo 6 Music/DTS Neo 6 Cinema or Auto.
  • 11-21-2010 11:05 PM In reply to
    • Russ
    • Posts 641
    True Pavur, but that affects how the BeoSystem 3 'upmixes' 2-channel sources for surround.
    McLean, VA USA
