Whatever you do, DON'T get tempted into adjusting laser current etc.
You can easily measure the laser current but don't touch any adjustments.
The majority of faults in these decks are exactly capacitors and the ones on the
servo board in particular.
C2103 needs to be a blue Philips. Forget low-ESR and other "hype" types.
