Hello all Quick question If i have a bv7 in the main room and add a beocenter 1 in the bedroom I know i can disable the radio but how will the two DVD players function on the same master link....
Beovision 7 MKIV (Blu Ray)Beolab 9Beolab 6000Beo 4Beocenter 9300Apple TVSKY HDOptoma HD65 ProjectorLintronic TT455-RT-238Beovision 3 MKII
Should work like all sources you have in the main room and in the link room.
In linkroom:
BC1 DVD - press DVD
BV7 DVD - press LINK DVD
Stefan
Oh i see i have never used the link button before So if i have a apple tv connected to the bv7 as vmem connected by hdmi only I can access the vmem sound on my audio room by pressing vmem in that room and it works How will i access the sound from this device in the bedroom av-vmem or link vmem of some sort Cheers
If you have no V.MEM source in the bedroom, press AV - V.MEM. IR receiving device in the bedroom must be set to V.OPT 6. But as far as I know, HDMI (digital) sound can`t be distributed via Masterlink....
I just won an avant on eBay and it has a video player install but i will disable it You can distribute sound over the ml when only connected via hdmi if bv7 has the latest software I share my apple tv sound to my music centre in another room and it works perfectly
