Latest post 11-15-2010 5:57 PM by Jonathan. 14 replies.
Page 1 of 1 (15 items)
  • 11-02-2010 1:43 PM
    Beolab 3 problem
    I have owned Beolab 3's for a few years and sadly they have developed a problem. Every once in a while I hear a loud tick which is quite disturbing... Any ideas?
  • 11-02-2010 2:25 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Beolab 3 problem
    What are they connected to - and are you using Mk2 or Mk3 cables?
    Lee
  • 11-02-2010 3:19 PM In reply to
    Oops I forgot to mention. They are connected to a Beomaster 7000 and I use Mk3 cables.
  • 11-05-2010 2:38 PM In reply to
    Anyone?
  • 11-05-2010 2:45 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    I wish I could help!
    Perhaps a static discharge? Confused
    Evan
  • 11-05-2010 5:53 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Since Lee mentioned cables, maybe you should try a MK2 set and see if it changes any.
    Evan
  • 11-06-2010 8:24 AM In reply to
    You know what, it might just be a static discharge... Is this harmful to the speakers and how can I solve this? AFAIK MK3 cables are the one to use instead of MK2...
  • 11-06-2010 9:19 AM In reply to
    Mk3 is correct, but to resolve buzzing -not "ticks."
    What is the frequency of the ticks, or are they just random, sometimes not occurring at all?
    • B&o bottle opener
  • 11-06-2010 1:04 PM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Could it be a mobile phone, cordless phone, garage door opener, microwave oven, wireless lan bridge/repeater, telephone repeater etc. , just something you added/replaced/moved lately....?
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 11-06-2010 1:11 PM In reply to
    Exactly the direction I was headed... Yes -  thumbs up
    • B&o bottle opener
  • 11-06-2010 11:22 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    beocool:
    If it is a high pitch static charge it usually hits the tweeter, the weakest part of the speaker.
    Evan
  • 11-07-2010 4:41 AM In reply to
    kallasr:
    Ralf
    You know what... It might just be the microwave! Surprise I'm not at home right now, but I will give it a try next week. Thanks! Yes -  thumbs up
  • 11-14-2010 10:56 AM In reply to
    Microwave disconnected. Problem solved. Yes -  thumbs up Smile Thanks for your input! Yes -  thumbs up
  • 11-14-2010 12:54 PM In reply to
    I had exactly the same problem when I connected a fridge in the same circuit as my BL 3 speakers... I almost freaked out when I heard it the first time!!
  • 11-15-2010 5:57 PM In reply to
    Beo_freak:
    You mean: "I almost 'Beo_freaked' out when I heard it the first time!!"
    LaughingLaughingLaughing
    My B&O: 2009 Catalogue and Pricelist
