Hi there,
   I have a question for the technical guys out here that already helped me so much till now :)
   I recently bought an LC2 light controler and will mount it on the wall trying to control  a normal lamp.
   I saw in a few B&O demos that lights would go at x% of the initial intensity when they strated the audio systems.
   How can they do this? I think  a certain type of transceiver is needed or something in order to integrate the LC2 with my other B&O systems or this can be made just by programing the LC2 or the Beo 4 maybe?
Thank you in advance for your answers
Regards,
Stef
