The glassfront is waiting to be put back.
The panel was easy to put back. Just two cords that needed to be put back in place, and a number of small screws. There we needed to be two persons holding the panel.
It was quite difficult to put the glassfront back in place, and I had to help the engineer. It fits really tight to the chassi, but we managed.
The engineer had a powerful portable compressor so he could blow air over the panel and the glassfront to make sure there was no dust added.
So, all in all a successful surgery.
Thank you B&O!
_____________
Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
1:st prize winner Beoworld January Price Draw.
