Hi
If you ask B&O they surgest a "Atlona HDMI matrix" to link HDMI signal.
I have purchased a HDMI splitter 1 in & 2 x out, as i currently only need HDMI signal, linked to 2 sources. BV10-40 in main room, and BV8-40 in bedroom.
In my setup, the HDMI source is my PS3, that i use as Bluray/ DVD/mediacenter. from that i connect the HDMI cable to spiltter, and distributet it to the 2 rooms.
Setup DVD source on both TV´s And then i connectet both of the PUK IR-cables. from each TV, to my PS3.
Now i can control and se HDMI picture from both Main room and Linkroom.
But with all that said... could´nt you just buy a CAM Module for the BV8 & the BV7... plug in you Sky-card, and reseave it that way directly to the TV without the SKY-box. ? ? ?
